CA Clutch Rebuild
Carman
11-06-2003 07:29:33
As mentioned previously, I just replaced the clutch on my CA however, the engagement is right at the end of the stroke on the clutch pedal. How do I move the engagement further "up" on the stroke of the clutch pedal?
Pon
12-02-2003 22:58:53
 Re: CA Clutch Rebuild in reply to Carman, 11-06-2003 07:29:33
Carman, be sure the fingers on the clutch are up to specs also. Usually that'll do the trick if they're right. God Bless.
Dick L
11-06-2003 08:14:00
If you don't run out of threads, you should be able to remove the clutch rod from the clutch peddle and turn it counter clock ways to make it start to put pressure on the throwout bearing with less clutch peddle travel.
I have had to put a longer rod in some that did not have enough threads. I have had to change the throw out bearing retainer lever because the hole that the threaded insert swivels in that lever had become to big and oblong.
