5050 3pt hitch
Kraig
11-04-2003 22:23:21
The 3 pt hitch on my 5050 only raises about 6 inches and stops, what am I doing wrong or what could be wrong?
danny
11-09-2003 09:50:14
 Re: 5050 3pt hitch in reply to Kraig, 11-04-2003 22:23:21
Mine is doing something similar. It doesn't raise if you pull the lever all the way back but will raise a little if you pull it all the wat back, move it about halfway forward, and wiggle it for a while. Any ideas?
Kraig
11-09-2003 13:31:58
 Re: Re: 5050 3pt hitch in reply to danny, 11-09-2003 09:50:14
Remove the lever handle from the shaft that goes into the side of the three point hitch housing, and turn it with vise grips, that is how I confirmed my handle was slipping around the shaft. I moved the draft sensing lever which is down on the side there also. see if it changes things.
kraig
11-05-2003 20:20:41
I found the problem, the key was sheared between the lever and the operating shaft
