D-19 engine
J.G
11-04-2003 08:35:05
Had my trusty old D=19 diesel on the corn auger the other day and noticed when I went to shut down it had a slight knock in the engine. Probably a bearing getting bad. The tractor is in excellent shape; good rubber.tranny. rear-end and tin but I not going to spend 2000 dollars to over haul it. I know where there is a combine engine for 500 dollars (gas) but will it fit in my tractor. The tractor is used mostly for PTO work no heavy work. Thanks
larry
11-09-2003 13:17:22
 Re: D-19 engine in reply to J.G, 11-04-2003 08:35:05
If you don't want to fix the tractor, I'm interested in it as is if you want to get rid of it.
Eldon
11-04-2003 10:51:46
I believe you will have to modify the front motor mount, get a different governor and the hole in the hood for the exhaust pipe has to be moved.
scotc
11-06-2003 21:50:30
 Re: Re: D-19 engine in reply to Eldon, 11-04-2003 10:51:46
C2 combine engine = D-19 engine. governor doesn't quite work the same but it bolted right in, did us good, cheaper than replacing the cracked heads on our deisel engine.
BRAD TN
11-04-2003 16:57:53
IF you are going to get rid of your diesel engine keep me in mind and how much would you ask for it THANKS BRAD
Roland
11-08-2003 16:32:23
 Re: Re: Re: D-19 engine in reply to BRAD TN, 11-04-2003 16:57:53
I might be interested in the engine also.Thanks
