Will WD radiator fit my AC 100SP Combine?
peabody
11-04-2003 07:47:30
This is both a Allis Chalmers and Combine question. I have a bad leak in my Combine's radiator. I doubt that the combine had a radiator specific the AC 100SP. There are plenty of aftermarket sources for tractor radiators, if I just knew what one would work. Is it the same as the WD? I show an Allis Chalmers part number of 525669.
Eldon (WA)
11-04-2003 10:57:00
 Re: Will WD radiator fit my AC 100SP Combine? in reply to peabody, 11-04-2003 07:47:30
I'm not sure if the WD45 radiator was any different, but I would go with it....you may get a little better cooling. I think I read that they had cooling problems, but I'm not sure if they changed the radiator or just the sheetmetal ducting.
peabody
11-04-2003 11:22:15
 Re: Re: Will WD radiator fit my AC 100SP Combine? in reply to Eldon (WA), 11-04-2003 10:57:00
I'm looking for a radiator that will fit. If the WD45 won't fit, then I may as well use one out of a DeSoto. Does anyone know if the WD45 will fit?
Eldon (WA)
11-04-2003 12:12:53
 Re: Re: Re: Will WD radiator fit my AC 100SP Combi in reply to peabody, 11-04-2003 11:22:15
Send me the dimensions of your radiator and the hose locations and I will check them against my 45....the closest SP100 is 20 miles away....my email is [email protected]
