Allis Chalmers Model C Hydraulics
Chris g
11-04-2003 05:30:00
I have a 1948 model C with out Hydraulics. Did this come as an option and can I add it to my tractor?
Eldon (WA)
11-04-2003 12:09:58
 Re: Allis Chalmers Model C Hydraulics in reply to Chris g, 11-04-2003 05:30:00
If you have a pto assembly and it has a cover held on by 4 bolts on the RH side, all you will need is the pump, hoses and cylinder(s). If you are going to put on the an aftermarket 3pt set-up, you won't need the cylinder as they have their own. The pump bolts onto the side of the pto housing and runs off the pto shaft. Some pto assemblies didn't have this cover, and some tractors had no pto assy at all - so you would then need the appropriate pto assy. Should be plenty of used units out there....I may be interested in selling one of mine. Email me at [email protected] if interested.
