Starting a B
Tim
11-03-2003 21:23:32
Stupid question, but I'm new to tractors. How do you start a Model B or C? I've noticed there is not a keyed ignition switch like a car. Also how much throttle, and is there a choke? I would like to buy a B or C but dont want to look like a complete twit when start looking at one. Thanks in advance for any help. Tim
Eldon (WA)
11-04-2003 11:10:55
 Re: Starting a B in reply to Tim, 11-03-2003 21:23:32
No reason to feel stupid....a lot of the starting systems were changed over the years anyway. The early Bs and some Cs without electrics had no switch, just a kill switch on the mag (some have a toggle switch wired to the kill switch on the mag). On these, the choke was worked manually at the carb as you hand cranked them. I've got electric models with key switches and toggle switches.....one has electric key start with solenoid, others have foot starters on the RH side near the brakes. Some had pull rods near the stearing column...RH side goes to starter, LH side goes to the choke.
Just look at the starter and carb to see where the linkage goes....chances are they will all be a little bit different.
Tyler(WA)
11-04-2003 12:02:30
 Re: Re: Starting a B in reply to Eldon (WA), 11-04-2003 11:10:55
Hey Eldon,
Good input.
Email me. I have something you might be interested in.
Eldon (WA)
11-04-2003 12:21:39
 Re: Re: Re: Starting a B in reply to Tyler(WA), 11-04-2003 12:02:30
Tyler...looks like you covered the hard part (handcranking) LOL!
I don't have your email....try mine: [email protected]
Tyler(WA)
11-04-2003 10:58:14
If you are talking about one without a battery or starter, it's a hand cranked machine.
Start by making sure you have the brake set and the transmission in neutral.
Check all fluids: fuel, oil, coolant.
Double check that you have the brake set and the transmission in neutral.
Open the fuel valve on the sediment bowl filter (2 or 3 turns.) It's mounted under the front of the fuel tank on the carberator side.
On the carberator, near the joint where it mounts to the air cleaner, there is a flat tab "lever" that works the choke baffle. When the lever points down it's in full choke. Start with full choke.
Check again that you have the brake set and the transmission in neutral (are you getting the point here?)
Insert the crank through the hole at the bottom of the radiator coul so that it engages the pulley on the front of the engine. There are two lugs that fit into slots in the pulley.
Now this is VERY IMPORTANT: This is where you'll break your arm if you don't do it right. The engine can kick back with a lot of force put back on that crank, you have to allow for it. Don't grab the crank with your thumb but cup the crank handle with your hand remaining outside of the rotation. Think of the circle of travel the crank will make as it turns the engine. It's natural to crank with your hand holding the handle from the inside of the circle but that places your arm where it can get clobbered if the crank were snagged on the pulley of a running engine. Keep your bodily parts out of that circle. Start with the crank at the bottom and bring it up slowly until you feel compression (should be about the 9 o'clock position.)
Pull the engine over smartly (quickly) in a clockwise direction. You'll only get one compression cycle for each pull so go back to the bottom and "catch" it again. After a couple compression strokes, it should "pop" as it tries to fire.
Reset the choke to about 1/2 and crank it again.
A properly tuned engine should fire and run in juat a few cranks. Mine will fire on the second crank unless someone's looking.
NOW: If you're talking about an electric start model.... There's a rod that pushes a switch button on the electric starter. You can push it with your right foot from the tractor seat.
Good luck.
Remember, there's never any shame in asking the owner to start it for you. Most tractors have some tricks to starting their particular engine more easily.
Tyler(WA) Almost forgot..
11-04-2003 10:59:37
 Re: Re: Starting a B in reply to Tyler(WA), 11-04-2003 10:58:14
Set the throtle at about 1/3.
