Alils-Chalmers B
Slowpoke
11-02-2003 23:23:46
Well, I think it's a B. Very wide rear end, long torque tube, mag, non adjustable wide front end. Very low fenders. To left of pto is 3 grove pulley in place of flat pulley. Hydraulic cylinder next to each fender operating some kind of rock shaft. Coolant in radiator, sheet metal, grill OK. Steering rod sticks way out on left side. About 24" wide seat (only springs left). No carb, exhaust open, engine frozen, shift lever boot bad, right fender rusted out, tires up, 30% tread.
Western Gear auxillary transmission in front of 3 speed transmission. Plate reads: lo, lo-lo, regular. Comes with narrow front also; unknown if single or dual wheels.
Any ideas on as-is-value?
Thanks
eldon
11-03-2003 07:33:09
 Re: Alils-Chalmers B in reply to Slowpoke, 11-02-2003 23:23:46
Sounds more like a C with a B front end. $500, worth more if nf is SFW
steve
11-03-2003 15:23:21
 Re: Re: Alils-Chalmers B in reply to eldon, 11-03-2003 07:33:09
with bald tires and motor locked, thats high. I would be more in the $300. range. personally i never saw the extra trans on a C.. I agree, probably not a B, or maybe a mixture of parts B and C. serial number is by the shift lever.
