allis b hyd,cylinder
wilburn
11-02-2003 15:46:55
i am going to have to replace my hyd. cylinder on my b. the local tractor supply store has cylinders .but they are double action with a place for 2 lines where as mine is ,i think is a single action with only one line.my question is will the double action cylinder work on my allis b thanks
D13
11-04-2003 14:06:01
 Re: allis b hyd,cylinder in reply to wilburn, 11-02-2003 15:46:55
You need a vented plug on the rod end. This lets the air out as the pison moves up the bore.
Als, be careful of the side of cylinder. The tractor does not have a big resevoir and running it dry will destroy the pump. I think the biggest they recommend is like 2x8 or so.
Kevin (FL)
11-06-2003 08:28:29
 Re: Re: allis b hyd,cylinder in reply to D13, 11-04-2003 14:06:01
Wilburn,
Good point on the vent plug at the rod end. Where are those available? Do they have some sort of small filter to keep trash out of the bore?
wilburn
11-04-2003 18:21:31
fellows ,thanks for your input it has helped me a lot .this site is wonderful.again thanks to the both of you.
Kevin (FL)
11-03-2003 21:28:28
Wilburn,
I can't be 100% sure but believe that will work. You'll only have to connect the the 1 line and leave the upper port plugged. The only part I wonder about is whether the double acting cylinder needs the oil on the upper side for lubrication of the seals. Ask the salesman to consult with his supplier, but I think you'll be OK.
