What is this C worth?
Farmall Daddy
11-01-2003 14:24:03
Was returning home from town, and seen an Allis C setting for sale along side the road. I stopped and looked at it, but didn't get out of the car, since there wasn't anywhere to park. It has mismatched rear tires, but the left side one is replaced, and looks new. Sheetmetal looks to be in good shape, as in grill, hood, etc. They want $600 for it. Does this sound like a resonable price? I own a WC Allis, and that is about all in the Allis fleet. What are some things to look out for? Thanks for advice!!
Al L. in Wisc.
11-02-2003 06:13:17
 Re: What is this C worth? in reply to Farmall Daddy, 11-01-2003 14:24:03
Steve has some good points in his checklist. I would add that (not knowing your use, as in acreage to mow, for example) you could spend thousands of $$$$ on a rider and just be able to mow with it. Not pull a plow/spreader/wagon/blade snow, etc. $600 sound like a possible money-maker for you if nothing else.
Dick L
11-02-2003 10:19:48
 Re: Re: What is this C worth? in reply to Al L. in Wisc., 11-02-2003 06:13:17
Al L, I would guess he was not thinking of mowing. I saw that dreamy evel look in his eyes when he hooked my C to the sled at Blufton Indiana. He sure likes those trophys. {:^D
Farmall Daddy
11-02-2003 14:42:59
 Re: Re: Re: What is this C worth? in reply to Dick L, 11-02-2003 10:19:48
Thanks for the comment. I am not really looking for another puller, but for something to maby play around with. Have to get the WC put back together hear pretty soon.
Dick L
11-02-2003 16:38:41
 Re: Re: Re: Re: What is this C worth? in reply to Farmall Daddy, 11-02-2003 14:42:59
I thought all pullers would pull anything they could figure out how to get on a trailer. {:^D
Farmall Daddy
11-02-2003 17:09:28
 Re: Re: Re: Re: Re: What is this C worth? in reply to Dick L, 11-02-2003 16:38:41
I don't have the room. Have to figure out how to get the 560 to pulls right now.
Dick L
11-02-2003 17:22:40
 Re: Re: Re: Re: Re: Re: What is this C worth? in reply to Farmall Daddy, 11-02-2003 17:09:28
I cant remember which engine show it was but a guy had two tractors with tow bars hooked to the frond wheels somehow. You could fix all your tractors that way and pull a tractor train to the pulls. Every body would remember who you are when ya whipem ina pull. {:^D
Farmall Daddy
11-03-2003 15:15:33
 Re: Re: Re: Re: Re: Re: Re: What is this C worth? in reply to Dick L, 11-02-2003 17:22:40
Yeah, hooking tractors together would give me a name for people to know me by. What kind of motor work do you have to do so you will have enough power to pull it in the 0-2800 pound class? I figured I would ask you since your C is a heck of a power house!
Dick L
11-04-2003 08:50:49
 Re: Re: Re: Re: Re: Re: Re: Re: What is this C wor in reply to Farmall Daddy, 11-03-2003 15:15:33
I didn't think anyone could tell!{:^D
Sleeves, Pistons, Rings, Reground crankshaft, Head machined to fit pistons, Cam shaft up to new engine specs, and a carb rebuilt to let the right mixture thru.
Farmall Daddy
11-04-2003 13:21:42
 Re: Re: Re: Re: Re: Re: Re: Re: Re: What is this C in reply to Dick L, 11-04-2003 08:50:49
So if I oversize the pistons, mill the head or put shorter valves in, and bore the main jet, it would have enough power to pull the light classes? Did you pull your C in the 2801-3500 this year?
Dick L
11-04-2003 20:04:19
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: What is th in reply to Farmall Daddy, 11-04-2003 13:21:42
Pulled at 3200 in the Banet class at New Haven.
I think I got third but went to far to the left and drove into a soft spot. Dick Erwin drove a tractor width to the right of where I went with that To 30 with the step down and put 20 feet on me.
Farmall Daddy
11-05-2003 13:12:49
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: What i in reply to Dick L, 11-04-2003 20:04:19
Yeah, Dick Erwin is a hard one to beat. His minnie mo, and that little ferguson will show you what they got on a good track. Are you going to Waseon Ohio the day after Thanksgiving?
Dick L
11-05-2003 13:38:17
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Wh in reply to Farmall Daddy, 11-05-2003 13:12:49
Just ask Dixie ifins I could go and I ain't gots an answer yet. {:^D
I might go if I can get out of bed that early.
Your guess is as good as mine.
If I can't find any one else or any thing else to blame, I will be there.
I think so.
If you go and I aint there ya will get the idea I didn't make it. {:^D
steve
11-01-2003 18:38:37
if it runs i would pay $600. if it sets outside and the rubber around the shift lever is bad, it will certainly have some water in the oil. no dip stick, fill is by your left foot on transmission side. 3 drain plugs on bottom. same oil in trans, pto, and steering.---see if front end has any steeering slop, run it around and see if it jumps out of any gear. normally the B-C are o.k. in this area. they were 6 volt positive ground originally. see if it has this, or converted to 12 volt alternator. different tires can be expensive, but if you dont mind the mismatch----- ----
