WD45 1/4 inch x2 inch pin in oil pan.
D. WILL GREENWA
10-31-2003 16:18:52
Just bought a 49 WD with a 45 engine. Operates fine. Want to use good clean oil so I pulled valve cover ,which was clean, then pan. Found some small bits of metal and this 1/4" pin with snap ring groves in both ends.Small amount of sludge.The manual shows a pin in the governor, could this have dropped during overhaul. Yes i"m a new owner with a manual. P.S. also a green "B". THANKS/ D.WILL Greenwald
Will Greenwald
11-02-2003 14:39:45
 Re: WD45 1/4 inch x2 inch pin in oil pan. in reply to D. WILL GREENWALD, 10-31-2003 16:18:52
A big thanks to all who answered with help about the 1/4x2inch pin in my oil pan. John, Sam H.,Moonlite and Dave maddux. Like I said I got a J.D. 'B' but kind of starting to really like this ole WD. D.Will greenwald.
John Thumma
11-01-2003 08:15:56
SamH is spot on right. WC's, WD's, 45's and D17's (all the same basic engine) had a real problem with this. I have owned a WC, WD, and 4 45's and have had the governor weight come unglued two times.
Makes for a lot of power and a real interesting ride when it happens. There is almost always some chunks that make their way to the pan. Nothing to worry about as I think the weights are made of a fairly soft material.
JT
SamH
11-01-2003 06:11:53
Same thing happened to me when I bought my D-14. I figured the last owner blew out the governor and just didn't bother to remove it from the oil pan. This must be a common problem.
Sid
10-31-2003 17:24:50
I found something like that when I first changed the oil in my WD it was stuck to the magnetized drain plug. I took it to an old Mechanic that had worked on a lot of Allis tractors and that is what he said it was.
moonlite
10-31-2003 17:19:30
Most likely a previous owner broke a governor weight and replaced it without removing the pan. Seems that the older governors used a pin with cotter key
David Maddux
11-01-2003 04:48:54
 Re: Re: WD45 1/4 inch x2 inch pin in oil pan. in reply to moonlite, 10-31-2003 17:19:30
Yep: Same thing on D-17, was changing oil and ker-plunk, oil is not supposed to make that sound. Had one chipped tooth on cam gear, but somebody had already fixed. Dave.
