hd6 chutches brake adjustment
robert
10-31-2003 15:47:05
I need to try to adjust the chutches & brakes . They work somewhat when you first start operating then they slowly go away. thanks for any help.
WayneB
11-01-2003 05:25:17
 Re: hd6 chutches brake adjustment in reply to robert, 10-31-2003 15:47:05
I have the late model HD5G,and the early HD6 models adjust the same; if so here goes:
Steering clutch adjustment is 1-3" of free travel on each lateral. Pull till you feel clutches start to engage; if 1-3" fine, if not adj. Free travel will decrease with wear. Adjust linkage by removing pin and changing rod length. Use a yard-stick held horizontal from dash to laterals.
Brake free travel is 1 3/4 - 2" free travel on each pedal. Adjustment is made by removing brake band hole access cover and adjusting band nut. There is a band supporting screw at bottom (access)that is jammed when adjustments final. Brakes are adjusted in 1/2 turn increments to accomodate lobes on adjuster.
Good luck.
BTW--I bought my manual on ebay for $5 plus shipping, a good investment. Parts cost me $9.
Wayne
robert
11-05-2003 12:42:53
 Re: Re: hd6 chutches brake adjustment in reply to WayneB, 11-01-2003 05:25:17
thanks i'll give it a try
Mike R. in N.C.
10-31-2003 20:41:25
A great site to get some help and info is called www.ibdozing.com they have the different boards for the different makes. You can do a search there and come up with lots of great info under clutch or brakes. hth Mike
