Allis C hydraulics
jason becker
10-31-2003 00:41:59
does the hydraulics run off the rear end oil or does it have its own resevoir. if it runs off the rear end oil do i use 80-90 gear lube?
Duke(WNY)
11-02-2003 15:03:40
 Re: Allis C hydraulics in reply to jason becker, 10-31-2003 00:41:59
The operators manual for my C calls for 20 weight non-detergent oil.
steve
10-31-2003 15:35:57
the transmission, differential and hydraulic/ pto are the same cavity. there are 3 of 1/2 inch pipe plugs on the bottom, one each cavity. there is one fill by your left foot on side of transmission. put in about 8 quarts of hydraulic transmission fluid, which is a 20 wt oil. you can get universal hydraulic trans fluid at Wal Mart, or any farm store.
Dale(MS)
10-31-2003 05:54:40
Jason, It uses same oil as the rear end.
Dale(MS)
10-31-2003 05:52:17
Jason, If it has hydralics use hydralic fluid or 30 wt. oil.(non foaming) Dale
