D14 pto shaft bent
SteveA
10-30-2003 13:46:21
I'm looking at a D14 that has a bent pto shaft, and also leaks oil around shaft. I'm not familiar with AC's and would like to know how bad a job this would be to fix. Any info appreciated. Steve
JMS/MN
10-31-2003 00:01:52
 Re: D14 pto shaft bent in reply to SteveA, 10-30-2003 13:46:21
If the shaft is bent, that is likely the cause of the oil seal leaking. If you can remove the shaft and straighten it, install a new seal, shouldn't cost much. Drain the oil, and if it's like the D17, remove the three bolt bearing retainer and the shaft should pull out to the rear. If you need another shaft, that's a bit more spendy.
norm
10-30-2003 18:01:37
THERE ARE 2 LENGTHS OF D-14 PTO SHAFTS--LEAKING JUST NEEDS SEAL CHANGED
