what size wire for WD wiring?
MIke
10-28-2003 15:30:23
Is 10 guage big enough for the starter wire, 12 for the generator wires and the ground, and 14 for the headlight and tailight wires, or should I go bigger?
Thanks,
Mike
R. Marg
10-28-2003 15:35:31
 Re: what size wire for WD wiring? in reply to MIke, 10-28-2003 15:30:23
depends on what you mean by starter wire from the battery to the starter you in what is called battery cable form the generator to the battery it should be 10 and the rest 14 but I always use 12 hope this helps
