parts for old AC grain drill
Bill
10-28-2003 11:34:03
I have a 1950s vintage AC graindrill with double sisk openers. Anyone know where I can get disk openers that will fit this thing? Looked in the Shoup catalog and they don't list anything for AC. Also need seed tubes as they are dry rotted. I called the nearest AC dealer (50 miles from here) and he said AGCO no longer stocks parts for anything this old.
Paul
10-31-2003 16:32:48
 Re: parts for old AC grain drill in reply to Bill, 10-28-2003 11:34:03
I found that the same disk is uesd on newer AC corn planters but must also be the double disk design, you may need to find some that are worn down a bit. The single disk for the grain drills is a concave disk.
Dave Grubb
10-29-2003 08:03:32
I spent one winter rebuilding an AllCrop drill and was able to get some parts from Sandy Lake Implement. The seed tubes are still available but expensive. I found some tubes in the Shoup cataloge that worked out ok. The grass seeder was the most difficult to rebuild and the seed tubes for it is no longer available. I did find a way to get it operational and I can explain the details to you if interested. My drills disc openers were ok to use. Give Sandy Lake (sandylakeimp.com)a try; they were a big help on my drill project.
