WD 45 Stuck engine possible cracked block?
Rob
10-28-2003 08:25:30
I was trying trying to get my neighbor's WD 45 running. He died about 10 years ago and the tractor has been sitting in a butler building since then. His niece who inherited his farm recently told me I could have it.
I remember that it had a leaking radiator so he would just fill it up with the hose and drain it after each use. There is currently no water in the radiator so I assume someone drained it, but not sure if the block was drained or not. The engine is currently stuck. When I pull the dipstick out there is some white goo on the bottom of the dipstick beneath the oil. Is this a sign that the block is cracked?
I hate to think that the engine is ruined because this is a really nice original WD45 and it even has a loader on it.
Russ
11-02-2003 17:48:44
 Re: WD 45 Stuck engine possible cracked block? in reply to Rob, 10-28-2003 08:25:30
WD 45; Don't bother with the electrical transformer oil it most likely has PCB's (Poly Chlorinated Biphenyl's. Unless your lookin' for a quick source of body tissue cancer.
Once you put in your oil, kerosene, PB Rust spray
or some combination of the above make a tent around the WD45 engine area and duct in heat from a heat source (Electric heater or kerosene
heater - no open flames of course and safety
at every oppurtunity. The heat will motivate the petroleum products to migrate more rapidly and get the loosening of parts that you are seeking.
Pull the engine head and inspect the cylinders for excess rust, carbon deposits and other contamination. Put your oily cocktail in the cylinders.
Try to get access to the starter ring and move it
back and forth in tiny increments.
If you start to get movement scrape out the cylinder bores with non-metallic's. Use a stone
hone and electric drill to clean and cross-hatch
each cylinder.
Vacuum out all the stoning debris and rust scaling.
You may need to pull the connecting rod caps on the crankshaft and pound up(use hardwood to prevent nicks and damage to precision surfaces) and out the pistons and connecting rods. Make sure the wrist pin moves freely on each assembly.
You would do well to get a tractor mechanics input along the way at several points.
Reassemble the above with new head gasket and overhaul gasket set.
Put in all new fresh oils and fluids. Enjoy
your unstuck WD45 tractor.
David
10-29-2003 20:09:29
If you want to have confidence in it when you are done you should tear it down and inspect all the parts and replace what isn't reusable. Get an IT manual which has disassembly and reassembly intructions and guidelines for determining what's reusable.It's a rewarding experience to get everything back the way it should be. If you try to start it with something stuck you could damage some parts.
INCase
10-29-2003 05:16:47
All engines have some moisture in them from normal use. If its sat that long the condensate most likely settled to the bottom (water) of the pan. The other oil locations will probably have some too but engines will probably have the most. Haven't tried turpentine... have heard PB blaster works well too for stuck engines. Have also heard electrical transformer oil works very well but haven't been able to get any (stuck 730 Case) which ever fill the cyl. until it runs out the plug hole (some may go out manifolds depending on valve position) If its truely stuck and its sat that long you may be wise to pull the pan and take a look. The cylinders may need cleaning (honed) and a new set of rings may be in order. DONT pull start it if its stuck.. good luck
Ron
10-29-2003 08:46:52
 Re: Re: WD 45 Stuck engine possible cracked block? in reply to INCase, 10-29-2003 05:16:47
Transformer oil may be extremely high in "PCB"'s
Be careful....!!!
Ron
10-28-2003 15:02:08
Remember that Many AC-WD type engines will have a cracked bottom web between a pair of cylinders, and it is NOT as serious as it seems...!! If that is where the moisture is coming from, it can be remedied pretty easily, without tear-down.. Not saying that it hasent frozen, but might be the source of the moisture..
Ron.
Dave K
10-28-2003 13:33:33
Try kerosene or diesel for soaking it. Not sure what turpintine will do to seals!! Myself I would pull the valve cover and look around, pull plugs and put kerosene in cylinders leave plugs out. The white crap in the oil is probably condensation and the tranny and hydrulics are gonna have it to. Drain them all, flush with kerosine and put in new, good oil. Final drives may need it also. Do all the lubrication per the manual. If there was condensation in the tranny you may have a cracked housing or PTO housing although you would probably see it leaking if it was cracked. I'd try cranking the engine over with the hand crank and then the starter after it soaks a while. Watch for a stuck valve, if you try to tow it to start and some valves are frozen you are gonna bend up things you don't want to bend!
Dave
R. Marg
10-28-2003 08:32:50
years of sitting probably has let water condence in it I'd fill the cylinders with turpentine after draining the oil and even fill the crank case with turpentine and let it sit for a few days that should free it up then I'd put freash oil in and go from there you may have a very good tractor that just needs a little TLC
