Smoking G
Scott in SC
10-28-2003 05:51:56
I have a G that smokes considerably when first started. After running for about 30 minutes or so, it nearly clears up.The compression is 80 to 85 lbs on all cyls., and it starts and runs fine.Is this the rings, or does it sound more like something else? I'm not much of a mechanic, so any help would be appreciated.Thanks in advance, Scott.
Dick L
10-28-2003 13:37:18
 Re: Smoking G in reply to Scott in SC, 10-28-2003 05:51:56
Probly rings. Sounds like it might have got hot and the rings lost some of its tension. Then as it warms up it tightens up enough to stop smoking. It is not like overhead valves where oil can drain past the stems. While sitting this engine will let the oil around the valve stems drain back into the pan.
