WD45 Starter problem? Switch?
WeekendFarmer
10-27-2003 10:29:40
I have a WD45 that was mowing fine until stopped for a break. Went to start it and nothing. Jumped the tractor from my pickup and nothing. I noticed that when I pulled the lever engaging the switch it pulled on the motor from the pickup. However nothing is moving on the tractor. Bad switch? Good switch/bad starter?
Any ideas? Thanks in advance.
Rock_Picker
10-29-2003 05:19:52
 Re: WD45 Starter problem? Switch? in reply to WeekendFarmer, 10-27-2003 10:29:40
Check your battery ground cable for a good connection to the tractor chassis. Also check the ends of both battery cables to assure that the terminals are not corroded and causing a poor connection..... ..... ..RP
John (C-IL)
10-27-2003 10:34:59
Take the starter loose from the bellhousing to determine if the starter is locked into the engaged position. You can also check to see if the starter will turn while not in the tractor with your jumper cables. BE CAREFUL DOING THAT.
Have you tried to manually engage the starter by pulling on the lever, not the control rod?
Let us know what you find out.
Weekendfarmer
10-27-2003 10:50:08
 Re: Re: WD45 Starter problem? Switch? in reply to John (C-IL), 10-27-2003 10:34:59
After thinking about that, I have a button on the side of the starter that is pushed by the control rod. I have not tried to push it with out the rod. However if this is recommended, I will try it this evening.
Thanks.
Weekendfarmer
10-27-2003 10:44:16
I will try removing the starter and using the jumper cables. What is the lever not the control rod you are referring to?
Thanks for the information!
Sid
10-27-2003 16:57:46
 Re: Re: Re: WD45 Starter problem? Switch? in reply to Weekendfarmer, 10-27-2003 10:44:16
I believe what he is refering to is down on the starter the lever that the rod pulls which in turn pushes the buttonon the starter sometimes when things get worn you can work it down there and get a better connection. I really think that could be where your problem is, but the dirty connections could do that as well.
Charlie Meakin
10-27-2003 14:39:05
I had the same problem on my WD-45 I took the battery cables off and cleaned them up and my problem was over. Hope you can have the same luck
Weekendfarmer
10-28-2003 07:25:35
 Re: Re: Re: Re: WD45 Starter problem? Switch? in reply to Charlie Meakin, 10-27-2003 14:39:05
OK. I tried pushing the switch on the side of the starter. I have a click (and it gets warm). There is a metal strap that I can remove on the back inch of the starter. I notice that it will try to spin only making it about an 1/8 of an inch. I don't see where I can remove this starter. It appears that the only way to get to it is from the rear of the starter. It appears to be pressed in the block? Am I crazy? Should I replace bushings? Any help is greatly appreciated. Thanks alot.
Dave K (FK)
10-28-2003 13:41:44
 Re: Re: Re: Re: Re: WD45 Starter problem? Switch? in reply to Weekendfarmer, 10-28-2003 07:25:35
The starter is held in by a bolt that screws into the side, It just sort of clamps it in there, easy to remove. Often you will get rust etc here so remove starter, clean up block and starter where they meet, remove the starter switch on top of the starter, clean up the copper pole (contact) on the starter and the copper contact on the switch. Make certain battery cable are clean and making good contact, this includes the ground to the frame. Don't know if you still have a six volt system in there or a 12 volt but the 6V should be a positive ground so remember that when jumpering! Most all starter problems are the cables and the switch. If nothing else works take the starter to a starter shop and have them test it.
Dave
