AC 190XT Steering
Ted
10-27-2003 07:00:41
Just bought an AC 190 XT (about a '64)and it takes a while for the steering to work. Previous owner says it worked fine prior to a recent hyd oil change and suspects air in the system. Does this sound right? Are they tough to bleed?
Thanks,
Ted
R. Mrg
10-27-2003 07:45:11
 Re: AC 190XT Steering in reply to Ted, 10-27-2003 07:00:41
sounds like it could be low on fluid I just sold one of those all I had to do to get the steering working well was fill it with fluid and sit there for 5 to 10 minutes and run the steering back and forth all the way and it started to work very well let me know if this doesn't work I still have the shop manual on itand I'll look it over if that doesn't work by the way hows the tranmission they are known to have problems
Ted
10-28-2003 06:30:44
 Re: Re: AC 190XT Steering in reply to R. Mrg, 10-27-2003 07:45:11
Thanks,
I did not personally check the fluid and will in a couple weeks when I get back to it. Aside from steering and rubber the trans everything else is in good shape.
Ted
R. Marg
10-28-2003 06:53:14
 Re: Re: Re: AC 190XT Steering in reply to Ted, 10-28-2003 06:30:44
I'd watch the tranmission they are weak also do not shift it on the fly that is what takes out the tranny
