Engine Building on a '39 B (con't)
Chris (OR)
10-24-2003 09:16:24
The real question is on the rods... I have yet to see the point of the shims if I am going to be running the crap out of this tractor. (I will be mowing in front of the house for an hour or two a week for several months out of the year). I have also been told the modern bearings (Clevite or the like) are much harder than orginal. The shims seem like a micky mouse way to build the thing. Should I really use the shims on the rods or should I have the rods re-machined to round (right now they are about .006 shorter top to bottom)?
Has any one out there really used one of these tractors enough to need to pull a shim out?
Thanks
Chris Horn
Scappoose Oregon
P.S. I found what the problem is with my trying to post to this board. You can't use words shi* or even pis* (as in to take a leak.... ) It will reject your post and not tell you why....
Dick L
10-24-2003 13:46:58
 Re: Engine Building on a '39 B (con't) in reply to Chris (OR), 10-24-2003 09:16:24
Just take the rods to where you had the block line bored and have them remachined to where the shims are not needed. I have had this done a two engines that I changed to a full pressure systems to oil the rods thru the crank rather than the spray on the rods from the cam.
