190 Alis question
Irishamerican
10-23-2003 08:55:16
I have an old 190 Alis. Where do you check the brake fluid at? My brakes don't seem to be working.
Also how about the power stering pump where is it located?
Thanks
JACK ROSS
11-02-2003 12:02:48
 Re: 190 Alis question in reply to Irishamerican, 10-23-2003 08:55:16
if any one can tell me what gas engine will bolt to my 190 xt.
orvil
10-24-2003 05:21:22
if you can't fix the brakes youself, be prepaird to shell out lots of cash. good tractor, gas or diesel.
Lil_Farmer
10-23-2003 12:41:54
No Brake fluid. Brakes are band and disc, dry type. No brakes usually means worn out.
Power steering is part of regular hydraulic system, uaing a priority and flow divider valve.
Irishamerican
10-27-2003 07:19:59
 Re: Re: 190 Alis question in reply to Lil_Farmer, 10-23-2003 12:41:54
Is there an adjustment for the brakes?
Thanks for the information.
Joe(TX)
10-27-2003 10:46:07
 Re: Re: Re: 190 Alis question in reply to Irishamerican, 10-27-2003 07:19:59
The adjustment is done by turning the bolt on the lever attached to the brake rod at the drum. The drum is on both the sides near the rear axle.
