Used D17 engines
Virgil Walden
10-23-2003 08:52:34
I don't know how to rebuild and engine and I have an engine in mine that is burning about 4 quarts of oil in a few hours time. Any idea where I might be able to find a better used engine? I am in Alabama. It is a D17 gas, trike front. Thanks
Virgil
CII?
10-24-2003 14:54:28
 Re: Used D17 engines in reply to Virgil Walden, 10-23-2003 08:52:34
Virgil,
I have a CII Gleaner with a 262 gas AC engine. I bought this unit in 1988 from the original owner. The unit has always been shedded and is located about 40 miles from you. I was told many years ago that it was the same engine as a D19. We have not planted grain in a few years and need the shed space. I might be interested in in parting with the combine or engine. Ask around if this engine might fit your D17.
Virgil Walden
10-24-2003 16:47:32
 Re: Re: Used D17 engines in reply to CII?, 10-24-2003 14:54:28
I heard that a Gleaner E combine is the same. That 262 sounds familiar. I think it is the same engine that is in my D17. How much might you be wanting for it?It might be a while before I could get it as I am having some problems right now, like no job. But I sure need to do something before the spring time frame. Just let me know.
Virgil
Kevin (FL)
10-24-2003 20:46:13
 Re: Re: Re: Used D17 engines in reply to Virgil Walden, 10-24-2003 16:47:32
Virgil,
I can't say for sure if that engine will fit, but it should. I thought you had a gas engine in that tractor. The gas models had 226 cu. in. 4 cyl AC engines and the diesels had a 262 cu. in. 6 cyl Buda design engine.
Virgil Walden
10-25-2003 06:08:30
 Re: Re: Re: Re: Used D17 engines in reply to Kevin (FL), 10-24-2003 20:46:13
Kevin, You are right, I do have a gas. The 262 just sounded familiar for some reason, but you are probably right. Mine is 4 cyl gas.
Virgil
Eldon
10-23-2003 19:42:56
There was a complete running engine for sale in the classifieds here a couple of weeks ago for $700 in Ohio I think.....you might try a search for "Allis"
Dan McClure
10-23-2003 18:07:13
Virgil find a gleaner E combine I believe they have the D-17 engine in them cheap route and there is alot of them around, also some probably have low hours
Virgil Walden
10-24-2003 05:53:12
 Re: Re: Used D17 engines in reply to Dan McClure, 10-23-2003 18:07:13
Dan, Thanks for the information. I will check that out.
Virgil
Kevin (FL)
10-23-2003 11:33:02
Virgil,
Whereabouts in 'bama are you? If you can remove and exchange your engine with a new one, you can probably rebuild the one you have. You do need some special tools that most folks don't have in their tool boxes though--Like micrometers, dial indicators, snap gauges, pullers, torque wrenches, to name a few.
I know a fellow that has a D17 he's not using with a single front, but I don't know if he would be interested in selling it. A running D17 engine is a little hard to find--most "laying around" already need rebuilding. A rebuilt one ready to go will cost quite a bit.
Virgil Walden
10-23-2003 13:14:50
 Re: Re: Used D17 engines in reply to Kevin (FL), 10-23-2003 11:33:02
Thanks for the info Kevin and yeah, you are so right about the engines needing rebuilt. I forget we are talking 1960 here. Ha! I certainly can't afford a new one or rebuilt right now and I don't have the tools either. I am in Hazel Green, AL; about a mile shy of the TN line.
Virgil
Kevin (FL)
10-23-2003 13:40:42
 Re: Re: Re: Used D17 engines in reply to Virgil Walden, 10-23-2003 13:14:50
Virgil,
I'll keep my eyes and ears open for an engine. In the meantime, there are "pour-in" products that make some pretty bold claims about stopping or reducing oil consumption. Some I've heard actually work pretty well. You can also get plugs that are made to handle oil fouling better.
Virgil Walden
10-23-2003 13:59:36
 Re: Re: Re: Re: Used D17 engines in reply to Kevin (FL), 10-23-2003 13:40:42
Thanks Kevin, I have tried that Engine Restore and all that, but haven't tried the plug thing. By the way where are you at in Florida? I was born in Kissimmee and did my High School years in Pensacola. I have plenty of relatives down that way. My Mom and Step dad live in Milton. Got any jobs in your area? I was working a government contract job up in MN and got laid off with two mortgage payments, now I am about to lose my house I need a job badly. I am a retired CW3 from the Army, a missile system guy, but have done lots of other things also. Thanks
Kevin (FL)
10-23-2003 20:45:04
 Re: Re: Re: Re: Re: Used D17 engines in reply to Virgil Walden, 10-23-2003 13:59:36
Virgil,
We're in Santa Rosa County, not too far from P'cola. The Ft. Walton/PC areas have several contractors that support the navy--I often see ads in the paper. We also have NAS Pensacola, Whiting Field and others. You might be able to get something going down here. Drop me an email at [email protected]. Remove "nospam" for email.
