carburator problem
don
10-22-2003 18:19:36
I have a WD carburator fills with gas but gas won't go through the jet took apart and cleaned but still can't get gas can spray starting fluid in intake tractor will start and die any help i'd appreciate
Steve in N.J.
10-22-2003 20:16:47
 Re: carburator problem in reply to don, 10-22-2003 18:19:36
Don,
Make sure the floats aren't real low. Also, could have the enrichment passage blocked with crud especially if it's a Marvel/Schebler. When we rebuild carbs for our customers, I usually run a wire through the lower passage, then the carb gets glassbeaded in and out to open the passages and get em' clear. It's the only way to get the old cast iron carbs clean....
Steve/B&B Custom Circuits
Dennis
10-29-2003 18:50:37
 Re: Re: carburator problem in reply to Steve in N.J., 10-22-2003 20:16:47
Steve,
You sound like just the guy I am looking for to work on a WD 45 carb. Email me at [email protected] and we can proceed further!
Dennis
R. Marg
10-22-2003 18:50:55
I had one like that on an 8N tried every thing to fix it but ended up buying a new /rebuilt one from a dealer some times the passage that you can not see get clogged with rust and can not be opened up again
