WD WC Head
Kevin (FL)
10-21-2003 19:20:46
I see a WD & a WC have the same engine (4-201). Are the heads the same also--completely interchangeable??
R. Marg
10-22-2003 08:36:02
 Re: WD WC Head in reply to Kevin (FL), 10-21-2003 19:20:46
same engines should be same heads but look for bolt holes that may or may not be there for external stuff like the gen. etc
David
10-22-2003 17:39:44
 Re: Re: WD WC Head in reply to R. Marg, 10-22-2003 08:36:02
WC and early WD had a thinner head than later WD and WD45. Also studs are different early to late.
Kip UT
10-23-2003 07:56:22
 Re: Re: Re: WD WC Head in reply to David, 10-22-2003 17:39:44
Except for very early WCs all WC,WD,&WD45 heads will interchange. Late WD & WD45 [tall] heads will freely interchange w/earlier blocks & viceversa, they even use the same studs.
