Liner O Rings
Leonard
10-21-2003 14:08:12
What kind of lube is used on these o-rings when installing the liners?
TimC
10-23-2003 09:38:07
 Re: Liner O Rings in reply to Leonard , 10-21-2003 14:08:12
Back in the old days my dad used brake fluid. You will probably get an argument on this but brake fluid is not supposed to hurt rubber from what i hear.
Arkansas Bill
10-23-2003 09:23:42
One point to remember about silicon rubber is to be sure and clean off the excess silicon rubber on the oil side. Otherwise, a small piece of silcon rubber may get sucked into the oil pump and create havoc.
wdTom
10-21-2003 18:34:19
There are many opinions on this one. Oil, grease, Silicone spray, O ring lube, gasket sealer, and some I don't remember. I wonder if the silicone gasket maker wouldn't be good as it would help seal. Although with good preperation the O ring should seal by itself. Some advise against a oil or grease saying it will eat the O rings, but I think they are Buna n, which is ok with oil and grease, and besides there is oil in the crankcase.
