Help with model and year
Melanie
10-21-2003 10:07:43
third party image
I believe I bought a 1930's model but am not sure. I have visited sites but cant seem to match mine. I beieve its a 30's because the front wheels are combined. On the engine by the transmission I found a # CE153494PA but cant seem to match it with any known #'s. I also have AM3797 # located at the rear axle. Ive encosed links for 2 pics if it helps. I appreciate your time. Any help would be greaty appreciated.
Thanks
Melanie
Link
http://www.hpphoto.com/servlet/LinkPhoto?GUID=711570f0-ac2e-768d-7862-2ce170613819&size=lg
Marty
10-26-2003 10:22:34
 Re: Help with model and year in reply to Melanie, 10-21-2003 10:07:43
This is a list of engine #'s that should help Link
Marty
10-25-2003 13:55:06
C's had the engine number on the left or rear side of the block but the CA had the engine number on the left side or on the rear flange as yours seems to be. CE153494PA would be 125 cu in engine used in the C, RC and CA. The high number would sound like a CA. Snap Couplers and live power clutchs were a option on CA's but not C's. Power Shift wheels were standard on the CA but not the C. THe C has a 600 rpm pto at 1500 engine rpm while the CA has a 538 rpm pto at 1650 engine rpm
Nathan (SD)
10-23-2003 07:13:43
You have a CA made after 1950
steve
10-21-2003 15:28:59
the picture is too small to see the rear wheel type, but this is either a model "C" or a "CA". I can see a starter and appears it has a plow behind, so i assume it has hydraulics. THE pan seat would make one think it is a newer CA model. The first C was built after 1940, so it is no older than that. Look by the transmission shift lever and see if the stamp says C or CA. the number after that will let us figure the year by looking to the left of this page. If the rear wheels are "spin out" type and the transmission is a 4 speed and it has a pan seat, this sounds like a CA. If it is a 3 speed with no spin outs, probably a C.
