what is it?
biscuit
10-20-2003 17:40:05
I recently got an old hay rake for a trade on some work. However I can't find out what kind of rake it is to get some teeth and bushings for the bars that hold the teeth. It looks like it was Orange in color and it is a pull type, but it is P.T.O. driven. The power goes from the P.T.O. to a pulley, then the power goes to another pulley by way of a belt, which in turn gives power to a a set of cogs and chain which in turn drive the rake bars. The rake bars and teeth appear to travel in a true circle with one steel plate on each end and one in the middle that the bars turn in when powered. It's frame is similar to the N.H. rollabar frames but the teeth turn in a true circle but the entire unit is at an angle to the tractor. It has 3 wheels, 2 small wheels (approx. 4in. rims) one on each side of the unit and one silly wheel in the rear middle.
help if you can.
