Parts Availability for WD in Western New York?
Moledoggie
10-20-2003 12:51:00
I acquired what I think is a WD tricycle which came with the house. It fired up for a short time, but nothing since. Where's the best place to get parts to get this tractor running again? I'm looking for tune up parts at first, but expecting to need model-specific replacement parts as I use the tractor. I'm located in western new york, just south of Buffalo. Also, how do I tell exactly which model and year tractor I have? Thanks, in advance, for all your help.
WNY Mick
10-29-2003 13:04:36
 Re: Parts Availability for WD in Western New York? in reply to Moledoggie, 10-20-2003 12:51:00
Moledoggie,
I live in Buffalo and have an AC Model B in Chautauqua. I've got parts and info from Steve at B&B in NJ and he's been great. Local Tractor Supply (Lockport, Fredonia) carries some basic AC parts and there's a lot of good sources on line linked to this site.
Mick
Moledoggie - Thanks to al
10-23-2003 20:47:32
Hunting camp is in Machias. I live in North Tonawanda. I found a place in Wheatfield called Maerten's that seems helpful. I now know I have a C model with many parts that are different from the manual (besides the 12V conversion). I flushed out gas tank, rebuilt the carb, drained the oil (oil came out after about 2 qts of water), installed new oil filter, plugs and plug wires. Finally got it to start but runs rough and needs to be choked. Get fair amount of gas flowing from the filter/shutoff - not a steady stream but probably enough to keep the tractor running. The throttle/governor linkage is sloppy and binds occasionally and there is a crack in the "distributor cap" part of the magneto. I assume the crack will have to be replaced soon but is not part of my current problem. Any thoughts on what next?
Thanks,
Moledoggie
Phill S. from MN
10-22-2003 09:08:50
You might also try Sandy Lake Implement in Sandy Lake, PA. I don't know how close they are to you. Website is www.sandylakeimp.com
Good Luck!
Steve in N.J.
10-21-2003 08:52:23
We can help you out with any electrical parts, wiring systems, tune up parts-(mag or distributor) some engine, drive train and fuel parts if needed. Located in Northern New Jersey..... www.chevy2performance.com or [email protected] (973)697-5747
Steve/B&B Custom Circuits
JD-Tractor in NY
10-20-2003 18:20:11
Alexander equipment ph. 585-591-2955 0r 547-3704
where about are you located ? I am here in Elba NY used parts from Galen LaWall in Batavia.
drop me an e-mail my add is uncovered !
JK-NY
10-20-2003 16:46:32
Look for an Agco dealer,if you ask around you might find one that was an A-C dealer before A-C was bought. TSC has a few tune up parts, also try NAPA, they can get sometune up parts and things. Best luck with a more rural NAPA that is used to Farm equipment. Used parts shouldnt be too hard to find either.
Dave K (SWFLA)
10-20-2003 14:10:14
e-mail me and I'll give you a run down on all your questions. Most all parts are available, some used some new.
Dave
Dave K
10-20-2003 14:12:06
 Re: Re: Parts Availability for WD in Western New Y in reply to Dave K (SWFLA), 10-20-2003 14:10:14
My e-mail was not visible. It is [email protected].
Dave
ken
10-20-2003 18:39:30
 Re: Re: Parts Availability for WD in Western New Y in reply to jim danforth, 10-20-2003 13:36:17
For used parts there is tam-car tractor parts. 1-800-458-3807 they`re in stow N.Y. the south side of lake chautaqua. I`m south of buffalo, where are you ? Hamburg??...ken
