Gear Jam
Gary Brendes
10-20-2003 11:47:55
My sons were out driving around yesterday and one shifted as the other was pushing in the clutch. Now I am stuck in low gear and the shifter appears to be in nuetral. Do I just take the cover off or the shifter out to get to the push rods to try and get out of first? Or, is it more serious than that?
Scott
10-20-2003 15:11:11
 Re: Gear Jam in reply to Gary Brendes, 10-20-2003 11:47:55
I believe you can just take the shifter rod out, and look down there with a flashlight in one hand, and a screw driver in the other, and get the forks in nutral again. Worn shifter is your problem
JMS/MN
10-20-2003 23:54:03
 Re: Re: Gear Jam in reply to Scott, 10-20-2003 15:11:11
Underneath the rubber boot, you should find a snap ring and a washer. Below that you will see the ball portion of the shift lever. If it is a WD, there will be a slot on one side (WD45 has a slot on each side). In that slot is a square-headed pin that fits into a round hole in the shifter tower. Do not lose that. Pull the shift lever straight up, and use a flashlight to see inside, while using a large screwdriver to realign all three shifter forks. Then reassemble.
gary
10-20-2003 15:18:17
Thanks I will give it a shot...
