5040 power steering
Loren
10-19-2003 07:46:20
Brother-in-law just traded for a 5040. Seems to function pretty well except for the power steering. Somebody has told him that there is a filter that is typically the problem. Can anyone tell me what that is and where it is? He has a manual ordered but as of now has nothing to get him started with this tractor.
Jason
10-22-2003 16:43:59
 Re: 5040 power steering in reply to Loren, 10-19-2003 07:46:20
I am not sure on the 5040 I know they are the same a a long but nut sure which type steering you have the one has a oil resivor under the hood right above the alternator and the filter is inside that the other gets it oil from the hyd system and the filter is in the line coming from the trans but the hyd would act up as well there is a relief valve on the pump of most of them.Make sure you get the right pump before you start looking on the bottom of the pump should be a screw head plug take that out and under that is the adjustment screw. Or it could just have a bad pump or seals inside
