Hydraulic Ram
Don Holden
10-18-2003 13:00:45
I have an opportunity to purchase an older AC disc that is in need of a hydraulic ram. My tractor has the original high pressure low volume hydraulic system. Where can I purchase the appropriate ram that will withstand the higher pressures that the piston pump developes and still be effective in raising/dumping the disc hydraulic oil thru the single inlet/outlet port of the tractors system.
john
10-18-2003 19:37:30
 Re: Hydraulic Ram in reply to Don Holden, 10-18-2003 13:00:45
tsc [tractor supply] has them
Don
10-20-2003 15:44:39
 Re: Re: Hydraulic Ram in reply to john , 10-18-2003 19:37:30
John, I thank you for the reply and information. We have a local TSC Store in the area and will run over and get the ram. I didn't know that TSC carried the low volumm high pressure system rams.
Thanks again
Don
