lost oil pressure after changing oil in d17
Larry
10-17-2003 19:32:00
my 58 series I d17 lost its oil pressure after changing the oil. it runs perfect and doesn't knock a bit, just doesn't show much oil pressure all of a sudden ( the "n" of normal, prior to this oil change on "r" of normal) any thoughts? It drops below normal range after it warms up. I've had the tractor for 3 years and not had any problems yet.
Bill (IN)
10-21-2003 07:02:09
 Re: lost oil pressure after changing oil in d17 in reply to Larry, 10-17-2003 19:32:00
If your eng ser. no. is 17-19978 or higher, all of this filter talk doesn't apply. This engine has a full flow filter system and the stuffed filters won't fit. AC changed the block, cam,& oil pump, along with the filter adaptor.
Duey (IA)
10-18-2003 21:29:58
third party image
The two types of filters
wdTom
10-18-2003 19:15:47
Two possible solutions. One is the filter as has been discussed. You need a filter with rag waste visible above a perforated bottom plate with a wood dowell sticking out of it. The dowell keeps the rag waste open so the filter can accept the tube sticking up from your filter base, which is solution two, You do have the tube sticking up from the filter base?? Without it you will not have enough back pressure from the filter to geve you good oil pressure. Go back in the archives, there is quite a bit about this problem there. Napa (at least mine) sitll has the wrong filters, checked Friday as I wanted one.
Steve in N.J.
10-19-2003 07:01:10
 Re: Re: lost oil pressure after changing oil in d1 in reply to wdTom, 10-18-2003 19:15:47
Tom, If ya need filters, we have a special goin' on em'. Fram C159's We just put another 60 in on the shelves. Drop us a line if interested....
Steve/B&B Custom Circuits
Ron
10-18-2003 08:21:08
May be the oil filter... The original oil filters have enough restriction to keep oil flow to a reduced level, so as not to bleed off oil pressure... I have heard of some after-market filters that allow too much flow, and can reduce oil pressure...be careful of these...!! If you are using the same gauge, and weight of oil, the oil pressure should be the same as before...!!
R. Marg
10-17-2003 19:37:01
any leaks like at the filter did you add enough oil i.e. is it low on oil wrong filter or going from a stright grade oil to a multigrade??
norm
10-18-2003 16:37:33
 Re: Re: lost oil pressure after changing oil in d1 in reply to R. Marg, 10-17-2003 19:37:01
did you use a new NAPA FILTER-- they had a batch of bad filters that was described earlier also AGCO had the same problem --but rectified theirs
