SERIAL NUMBERS
MIKE T
10-16-2003 19:22:56
I HAVE A ALLIS CHAMBERS WD. TRACTOR AND CAN'T FIND THE SERIAL NUMBER, WERE ARE THEY ON THE TRACTOR? AND DO NOT KNOW THE YEAR. PLEASE HELP ME OUT
THANKS
ACEd
10-19-2003 08:32:17
 Re: SERIAL NUMBERS in reply to MIKE T, 10-16-2003 19:22:56
WD tractor s/n may be in one of two places - most likely is as described elsewhere - on flat face on left side of rear axle - but other option is on top of rear axle at brake cover. In either case it will be steel stamped into casting and may be obscured by paint. I have also run across 2 WD tractors decaled as WD45's with s/n ground off - appears some sellers were unscrupulous and sold at higher price as WD45's. You probably should also check motor s/n on left side stamped in a flat space behind carb - if you can't find tractor s/n, Brian Smith's web site has a way to approximate the tractor year if motor is original.
MIKE T
10-19-2003 08:02:21
 Re: Re: SERIAL NUMBERS in reply to jim danforth, 10-16-2003 19:59:26
THANKS TO ALL YOU GUYS WHO REPLYED TO MY QUESTION....JIM D. R. MARG.....AND BRYAN SMITH
AGAIN THANKS FOR THE HELP
MIKE T
R. Marg
10-16-2003 19:28:29
my shop manaul says it is stamped on the rear face of the tranmission
Bryan Smith
10-17-2003 11:19:46
 Re: Re: SERIAL NUMBERS in reply to R. Marg, 10-16-2003 19:28:29
I have a picture of the location on my website (link below) if that will help.
