B front spindle diameter
D13
10-12-2003 11:33:54
Well I finally got around to working on the front of the B. The arms are WELDED to the spindles so there is no chance of disassembly (I bet that I've found 5 pounds of welding rod on this tractor). I need to take some of the up/down slop out of the unit so I plan on installing split machine bushings between the housing and spindle. Does anyone know what the spindle shaft diameter is? I'm talking about where it goes thru the axle bushings not at the hub.
Thanks!
c. Jackson
10-12-2003 12:35:49
 Re: B front spindle diameter in reply to D13, 10-12-2003 11:33:54
I have new bushings for the front of the B.
the spindle diameter is 1 1/4".
