195? wd
baker
10-11-2003 16:59:53
Would anyone out there know the approx wt.of my 1950 somthing wc?
Allis Puller
10-12-2003 01:00:32
 Re: 195? wd in reply to baker, 10-11-2003 16:59:53
Mine when it was bone stock - I could get it in the 3500# class with me on it. The shipping weights in the book are wrong. Any antique pull you go to the WD is in that class unless it had a wide front.
wdTom
10-12-2003 17:32:20
 Re: Re: 195? wd in reply to Allis Puller, 10-12-2003 01:00:32
Did you have to remove the PTO, belt pully, fenders,etc.? Most of the WDs is see around here in the 3500 lbs. class have been stripped like this. Or very close to it.
Allis Puller
10-13-2003 04:06:05
 Re: Re: Re: 195? wd in reply to wdTom, 10-12-2003 17:32:20
No not at the time I did'nt but I was only running 13.6 - 28 on the stock rim. I had the lift arms and cylinders still there too. It was complete. Granted at the time I was only weighing 150 lbs.
John (C-IL)
10-11-2003 19:15:47
your 195? WC doesn't weigh anything because production ended in 1948. However, the shipping weight on rubber was 4535 lbs. add fluid in the tires or any other weights and you can figure up from there.
wdTom
10-11-2003 18:14:36
If it has loaded tires probably somewhere in the 5500 lbs range, if they have only air, probably about 4000lbs.
