allis motor grader
chip b
10-10-2003 03:03:15
i have an allis chalmers motor graderand would like a little info on it .the serial number is 145 139. what model is this machine ? what year is it ? how much does it weigh? what size engine does it have ? the engine is an allis 6 cylinder diesel. any info you could give would be a great help thanks chip
Ken Campbell
01-02-2004 18:40:44
 Re: allis motor grader in reply to chip b, 10-10-2003 03:03:15
Chip:
Your AC grader 145 139 is a Model 145. Your particular machine (#139) was built in 1959. This 145 model was built from 1959 to 1963 and it had a 80hp Allis-Chalmers D-344 engine, the 344 standing for Cubic Inches. This gal weighed 21,540 pounds and had a standard 12 foot Roll-Away moldboard. In total they produced 497 of these machines between 1959 and 1963. They could also be fitted with a V-Plow and a wing plow and the hydraulics could exert 5 tons of downward blade pressure
steve
10-13-2003 15:24:27
chip, they made a 45 in the 1950 era, that was bigger than the D or DD. i believe it had a 6 cylinder diesel. you might check the guys at www.ibdozing.com and ask for info.
Rod
11-16-2003 01:33:44
 Re: Re: allis motor grader in reply to steve, 10-13-2003 15:24:27
Can you email me an image? I thought the larger (12ft) A-C graders had GM motors. Also, currently on Ebay.com there are quite a feww old A-C grader adds for sale, some with specs.
cheers
Rod
