Allis CA Tranny
John
10-08-2003 06:16:08
What is problem when CA jumps out of 3rd gear.
wdTom
10-08-2003 17:10:14
 Re: Allis CA Tranny in reply to John, 10-08-2003 06:16:08
I believe the CA is a constant mesh transmission. If it jumps out of gear the dogs on the side of the gear and the dog that engages them are worn. I have always wondered if it would be possible to remachine them. It would make a little more backlash but probably not to noticeable. New gears are likely to be in the hundreds of dollars range and I don't know about the dog that engages it. Maybe someone else more familiar with CAs will post too.
Ron Wi.
10-10-2003 20:58:39
 Re: Re: Allis CA Tranny in reply to wdTom, 10-08-2003 17:10:14
Take the cover off the side of the trans and check the spring steel tensioner inside the cover to be sure it is not bent or broken.
