WD hydrolics
Jon Olson
10-06-2003 18:08:56
My WD is having problems with the hydrolics. The problem is that the two point arm are staying up after a couple of times of use. I wanted to know if anybody thought it was the pump getting bad or if there is a problem with the torque tube. I am slowly trying to restore this tractor. I use it to mow with a bushhog. thanks for any information.
Dave in Eagan, MN
10-07-2003 08:39:20
 Re: WD hydrolics in reply to Jon Olson, 10-06-2003 18:08:56
I have a 1949 WD I have restored that was experiencing similar problems, and the pump had a persistent leak that I couldn't find. I took the pump off and took it to Gerlach, an Allis Chalmers dealer, in Old Cottage Grove. They replaced the rubber seals and springs and it works great and stopped the leaks. I can't remember how much they charged but it wasn't too expensive. There might be a kit out there, so if you were the adventurous type, you may be able to do it yourself. Good luck.
