WD gas leak carb, when warm
JWR
10-06-2003 11:54:56
Prior to clearing and burning brush this WE, I fully fueled my WD. Used it to pull branches up to the fire.
About mid day, the WD missed and quit. On trying to start, I saw the white smoke of a flooded machine. On dismount, noticed gas leaking from the carb.
I let the machine sit over night after turning off the gas at the bulb.
In the morning I had a brainstorm, the fuel cap wasn't venting and the gas expanded forcing fuel through the line. Especially considering the burning we were working around.
Opened the fuel cap and heard a slight woosh of pressure and figured that I had the problems solved. Pressure probably moderated over night.
However, each time I now start the WD, i t runs for 30 min or so and then dies and starts leaking fuel again. Flooded. No pressure behind the gas cap.
There are no cracks in the carb, it appears to be coming our from around the spring tensioned valve.
Anyone have any ideas?
Is this a carb rebuild issue?
Many thanks in advance,
jwr
jwr
10-10-2003 10:14:13
 Re: WD gas leak carb, when warm in reply to JWR, 10-06-2003 11:54:56
I have to confess to something (such as being a dummy). The carb DOES leak when the machine just sits. Forgot that the two times I restarted....I had previously shut the feul off at the settle bulb.
DUH.
So, it sounds like Dave nailed it. Is a carb kit just something generic I can pick up at an auto store or is it specific to the AC or the WD?
(I'm not too knowledgable as you can tell).
Thanks all,
jwr
Dave K
10-07-2003 07:55:35
Sounds like the float valve in the carb is sticking open. Why it does it after running a while I don't know. Thats about all that would make it flood like that however. This is a common problem (sticking float) You may have some dirt in there that is getting past the filter and causing the float neeedle valve to not close fully. Carb kit is about $30 and well worth it. Its also possible the float is leaking and, over time, filling with gas. When you shut off the gas it may drain and then run okay until it slowly fills again.
Dave
Sid
10-06-2003 18:24:48
Could it be a bad coil and the leaky carb problem started at the same time? One other thought would be that the float is loading up and flooding and over a period of time is draining out. How long does the tractor sit before it will start again?
Jim
10-09-2003 06:18:11
 Re: Re: WD gas leak carb, when warm in reply to Sid, 10-06-2003 18:24:48
I just started having the same problem yesterday! It runs excellant for about 30 to 45 minutes then just quits,sits awhile and then will restart and run 30 to 45 minutes. No leaking from the carburator though? Would a coil do this,or what would a coil do when it's going??
Sid
10-09-2003 23:19:10
 Re: Re: Re: WD gas leak carb, when warm in reply to Jim, 10-09-2003 06:18:11
What you described is what happened to me and it was the coil. the first time I had a coil go bad it did sputter before it quit. The leaking carburator has nothing to do with the coil. I thought his problem sounded like it might be a bad coil and the leak was just happen chance at the same time. Another possibbility with your problem would be that there might be a restiction in the fuel flow and it eventually runs the carburator dry and after sitting awhile it will start and run again until it runs dry again. This can be checked by taking the fuel line loose and letting gas run through it to check the flow. Next time it stops feel the coil and see if it is hot.
Jim
10-10-2003 04:36:43
 Re: Re: Re: Re: WD gas leak carb, when warm in reply to Sid, 10-09-2003 23:19:10
Yesterday it did it again so, I disconnected the fuel line and it seemed to be fine, cleaned out the filter and watched it re-fill, all seemed to be fine so, Iwent and got a new coil. Only ran it about half an hour before dark. Ran like it should, today will be the test. Thank You
