Allis Chalmers G stuck clutch
Russ
10-03-2003 18:50:56
Have an AC G thats been sitting for quite a while. Depressing the clutch pedal will not disengage the clutch.Any help/ideas would be appreciated.
Gordon
10-03-2003 20:52:17
 Re: Allis Chalmers G stuck clutch in reply to Russ, 10-03-2003 18:50:56
Does the rod to the clutch fork move? If not free up the rod at the foot pedal. If it does there may be a nest or material in the pressure plate or the pressure plate may be rusted tight. Then take the engine off " a easy project."
Tom Windsor
10-10-2003 19:39:48
 Re: Re: Allis Chalmers G stuck clutch in reply to Gordon, 10-03-2003 20:52:17
Does the Tractor Run?
Follow advice of previos follow up and check if there is movement of the arm from the throw out bearing. The fly wheel dust cover will come off and you can look up in there and get some feel of the problem. Most likely the disk is stuck to the clutch surface. I released one with a screwdriver while the clutch was disengaged. .
T
Russ
10-12-2003 14:03:46
 Re: Re: Re: Allis Chalmers G stuck clutch in reply to Tom Windsor, 10-10-2003 19:39:48
Yes, the tractor does run.
