3 POINT HITCH
DAVE JOHNSON
10-03-2003 14:05:45
I AM NEW TO THE TRACTOR THING AND I NEED HELP I HAVE FOUND A ALLIS CHAMBERS B FOR 1500 IT DOES NOT HAVE A 3POINT HITCH CAN ONE BE PUT ON WITH OUT MUCH TROUBLE ALL IT HAS IS A BUSH HOG
T.J.-N.J.
10-03-2003 17:34:15
 Re: 3 POINT HITCH in reply to DAVE JOHNSON, 10-03-2003 14:05:45
I have a worksaver 3 point on an Allis "C" that I bought of ebay from someone who had it on a "B". I like it on the "C" but he said he was terrified to use it on his "B" because it was so light in the front end. I use it with a tiller on my "C" and am going to use it with a flail mower next year. with a 5 foot brush hog on the "C" I can stand on the back of the mower and bounce the front end off the ground. I have a 4 1/2 foot tow behind that I bought for my "CA" If I was going to do a lot of work with a "B" I would try and get a tow behind mower, just remember that you don't have any hydraulics unless the pto is running' so unless you take off the shaft your mower will be spinning when you raise it. T.J.Ps. be sure to get an over running coupler to use with your mower
JEH
10-04-2003 05:23:06
 Re: Re: 3 POINT HITCH in reply to T.J.-N.J., 10-03-2003 17:34:15
Dave:
I second TJ-NJ on the use of 3pt on this type/weight tractor. Putting an implement way out back affects the CG-moves it way back. I added a 3pt to an old Farmall SC (about the same size as yours). I used a Saginaw (made in Saginaw MI) is very well made & HD. But in retrospect sorta wished I hadn't. Does work tho. You'll probably end up adding front weights which then affects steering. The thing in this weight & NF just wasn't designed for a 3pt. Anyway, that's my advice.
JEH
