Main Bearings on a '39 B (HELP!)
Chris (OR)
10-03-2003 10:29:10
Well I was trying to start rebuilding the block out of my '39 B. There seems to be no end play due to the front cap bearing (the one with shoulders). I can still spin the crank but it's an effort when I think it should spin and then coast.... Should I carefully hone off a .001" or so on each side of the shouldered bearing for clearance? Should I pull the timing gear forward .002"? It was getting late last night so I gave up before I made a mistake or broke something. The bearings are new Clevites and the crank is freshly ground.... Any one else had this problem?
Thanks
Chris Horn
Scappoose Oregon
Dick L
10-04-2003 14:50:24
 Re: Main Bearings on a '39 B (HELP!) in reply to Chris (OR), 10-03-2003 10:29:10
If you have shimed and used plastigage to check and have .015 to .002 clearance with the exact same amount of shim thickness on both sides of the main cap, You might have to file the bearing insert slightly. If you do file the bearings make sure you go back and recheck with the plastigage. Make sure to torque before checking the plastigage footprint.
wdTom
10-03-2003 18:06:47
If everything else is right and you decide to move the gear, I would make a shim to go behind it so you know justwhere it will end up.
Ollie
10-03-2003 17:29:57
I did the same thing on a rebuild once. I had one of the rod caps on backwards. Turned it like it was supposed to be and it spun freely.
