Wd engine serial number question
Bill
10-03-2003 04:16:07
What does PA at the end of the sn. stand for?
ACEd
10-04-2003 20:25:51
 Re: Wd engine serial number question in reply to Bill, 10-03-2003 04:16:07
Other response is correct, but heres more to it. Original gas motor for WD had GA suffix and was 5.5:1 compression (yes that low - that was before they had decent octane); In mid-1951 as I recall - at motor s/n 283022, they changed to the PA suffix which was 5.7:1. The K or KA suffix as I recall was in the high 4's say 4.7:1 maybe to burn distillate (kerosene) fuel. hope that helps. Ed
Brian G. NY
10-03-2003 16:40:41
The PA suffix indicates the "high" compression engine designed to burn gasoline only. If the suffix were KA, the engine would be a low compression engine designed to burn "distillate" (kerosene) as well as low octane gasoline. IMHO, the PA engine is the better for real work.
Bill
10-05-2003 15:36:46
 Re: Re: Wd engine serial number question in reply to Brian G. NY, 10-03-2003 16:40:41
Thanx
