Original Bevel or Replacement Four Loop Style Rims
wu
10-02-2003 21:55:51
I've heard about trouble with old style (bevel) rims. Apparently the bolts and clamps work themselves loose. Is this true? Which rims are the better choice, four loop or bevel style with clamps?
steve
10-03-2003 17:56:56
 Re: Original Bevel or Replacement Four Loop Style in reply to wu, 10-02-2003 21:55:51
you can buy the 4 loop new, they use them for IH tractors. If you want the original Allis wedge type, you must buy used. There are some troubles if the wedges (cams) are worn. If everything is to spec and assembled properly, there is no problem.
