1938 Allis WC
Randy L
10-02-2003 10:34:26
I've seen a 1938 WC sitting by the road near me. The sign says $1000 OBO. This machine seems Ok leaks oil (motor and trans well coated) and needs a front gril. Asuming it runs well too, Is that a good price?
JMS/MN
10-03-2003 10:59:05
 Re: 1938 Allis WC in reply to Randy L, 10-02-2003 10:34:26
Sounds too high for around here- sounds like an average tractor and I would expect 5-800 for it. Front grill?, like the radiator cowling? Mqajor part missing. If it is unstyled- since AC made the change about then, the unstyled had the 'square' gas tank and no grill, styled (by 39) had the round gas tank and the front cowling.
steve
10-02-2003 19:24:44
if you are buying to restore it might be o.k. if you are going to use it as a tractor, remember a WC has pto, but probably no hydraulics or lift system, just a pulling unit. IN the midwest you can get a WD for $700-800 if you look long enough. Like he said, depends on how bad you want it.
wdTom
10-02-2003 17:26:13
If it is styled, it needs a grill, if unstyled they don't have a grill. $1000 seems OK if it runs good and everything works I guess. Depends on the area of the country you are in and how bad you want it.
Randy L
10-03-2003 04:39:47
 Re: Re: 1938 Allis WC in reply to wdTom, 10-02-2003 17:26:13
Thanks Guys,
I got an AC HD5G a wile back and love it. I thoght that this WC might be a nice addition to my starting AC fleet. Could you make an unstyled a styled?
Thanks,
Randy
wdTom
10-03-2003 18:21:52
 Re: Re: Re: 1938 Allis WC in reply to Randy L, 10-03-2003 04:39:47
I don't see why you couldn't add a radiator, "shell" hood, gas tank and tank support, bellhousing with holes to bolt the tank support, and maybe some other parts I didn't think of. AC did it so can you if you want to. But why change the look of a great old unstyled tractor, they have character!
