C Allis rear wheels
Butch
10-02-2003 05:47:11
I have a C that I bought this spring to mow with, runs great ( after a couple people on here set me straight about the anti surge spring ). The problem is one of the rear wheels is loose, you can hear it "clunk" every now and then, also you can shake it and see that it is loose. The wedges seem to pull up to a shoulder and stop instead of getting tighter as you tighten the bolts. What is a fix for this ? I guess it is not going to hurt anything but I do not like the sound it makes. Thanks, Butch
Dick L
10-02-2003 06:27:33
 Re: C Allis rear wheels in reply to Butch, 10-02-2003 05:47:11
In time it will hurt something. The movement is wearing both the rim and the wedge clamps. The eccentric bolts with the dash marks will tighten and then get loose again after they go past dead center. I would jack up the rear wheel and remove all four clamps. remember that the solid bolt and the eccentric bolts are directly opposit of each other. Normally two of each per wheel. I have seen where three or even four eccentric bolts were used on one wheel. Because of the cost most will just shim between the clamp and the rim. I have taken off several sets that were atempted to be repaired with weld. No reason that welding would not work if a good job was done. The ones I took off were not a good job.
Butch
10-03-2003 05:25:18
 Re: Re: C Allis rear wheels in reply to Dick L, 10-02-2003 06:27:33
Thanks Dick, I did not know that there were eccentric bolts holding the wheels on. I will jack it up and see if all the "eccentric" is used up then I will go from there. Thanks again, Butch
