190 Fouling plugs like crazy!
Ryan
10-01-2003 19:29:05
My 190 Gas has been an excellent tractor for many, many years, but the last couple of months it has been fouling plugs like he!! I rebuilt the carb, Put in a new distributor, had it timed two times by local dealer, New air filter,etc. Still wants to foul plugs. It does use a little oil, but not enough to make it foul plugs like this. What else could it be?
Doug in OR
10-04-2003 07:34:25
 Re: 190 Fouling plugs like crazy! in reply to Ryan, 10-01-2003 19:29:05
What brand of plug are you using? Also, are you sure you are using the correct heat range?
Kent
10-01-2003 20:02:14
Do you think the coil is breaking down and not getting a hot enough spark? Just an idea??
Tonight my 190 gasser's throttle suddently stuck wide open and I immediately shut her off. The carb linkage had broken loose and was spinning on its shaft where the governor linkage rod connects. Had to take the carb off and braze it back together and now the governor actually works. It had me bafffled before this happened. Kent
