WD Allis Chalmers
Patrick Brown
09-30-2003 06:53:41
My WD sounds like it is skipping and Ive changed the points, condenser, spark plugs, and coil and still no change. Can anyone advise me on what might be wrong? I know I'm getting fire to all 4 plugs.
Dave K (FL)
09-30-2003 13:28:02
 Re: WD Allis Chalmers in reply to Patrick Brown, 09-30-2003 06:53:41
Does it do it under all load and throttle conditions?
Dave
David
09-30-2003 18:22:45
 Re: Re: WD Allis Chalmers in reply to Jim Danforth, 09-30-2003 07:08:52
My WD does the same thing. It pulls good with the main needle open quite far and idles good. It skips at light load above idle especially when hot. Ignition, compression, manifold is all up to snuff. Fuel level in carb is good. I am suspicious that the Zenith carburetor isn't right somehow and it's too lean in the mid range. Am tempted to try a Marvel carburetor.
