Sleeve seals AC B
Kenneth R. Boyl
09-29-2003 14:11:42
OK... I guess that I get it about the round o-rings. I am having to do a lot of polishing to get those seals to go in. I am using a 2" dia. sanding drum on electric drill w/ a short extension shaft. I find that I have to polish for ~ 1/2 hour on each one to get it tapered enough to insert seal w/o it squirting out.
Another subject: Manifold/muffler, Hole in Aftermarket muffler too small for muffler tube. Am I missing something here?? How is muffler supposed to attach to manifold? Do I need to open up that hole w/ my (smaller) sanding drum?
Kevin (FL)
09-30-2003 11:44:19
 Re: Sleeve seals AC B in reply to Kenneth R. Boyles, 09-29-2003 14:11:42
Kenneth,
We're still working on our 1st couple of B models, but the muffler I bought has a hole on one side only. The manifold is drilled and tapped to accept a bolt that you screw all the way across the manifold opening and seats against the inside surface of the muffler on the opposite side--kinda like a set screw on a pulley or coupling. As the bolt passes through the left side of the muffler, that locks it down so it can't fall off and when it jams against the manifold it keeps it locked in place so it doesn't rattle.
I can't help you on the o-ring part, we haven't gotten that far on ours. But I don't remember seeing in my manual where you had to do a bunch of sanding to seat the o-rings. Cleaning to bare metal--yes, but removing metal--I'd have to be wondering about that.....
