AC G Generator
Dennis of KC
09-29-2003 12:52:29
I am rebuilding an AC G tractor for someone else. What is the correct Delco-Remy model number for the 6-volt generator for a G? The model number on my generator seems to be 01854 8012. Strangely, after only cleaning up the generator, it is putting out 12-volts positive. The rest of the tractor has always been wired exactly like the G manual for a six-volt system. After adding a new 6-volt battery and 6-volt cabling, the tractor starts and runs perfectly on the six-volt system without the generator being connected. When I connect the generator, the ammeter goes into discharge. Thank you.
tom windsor
10-01-2003 21:23:19
 Re: AC G Generator in reply to Dennis of KC, 09-29-2003 12:52:29
1101854
Check the relay and see if it is burned out or stuck open.
